Building wall 4ft with pillers 4.5ft the wall is on a slope so wall is stepping down. The gate will be a double gate about 4.5ft.
However the pillers are same height top to bottom but because it's running on a slope ones lower that the other
So when gates hung you will see the difference.p What's your opinions on this or having the lower piller higher so gate won't look as if running off however the step then from piller to wall will be bigger on one side that the other.
