Hello,
I moved into this property just over 2 years ago. At the end of the garden is a double garage. I've got plans to convert them into a summerhouse type thing, but first of all I need to address a problem with the area at the front of the garages.
As you can see in the pics, across the width of the garage and about 3m deep is a slab of concrete. This area gets the best of the sun, and so it's a good place to hang out, sit and catch some rays, prod the bbq, hide from the kids etc. and so that slab gets used as a patio.
Much like many other things in this house, the concrete slab has a quirk. When it was laid, nobody really considered that drainage would be required. Before I start work on the garages (preferably) I need to figure out the best way to drain it. Water currently runs off in a number of different directions, including into the left garage and the workshop in the middle.
I've got a few ideas, but I'd like to see if anybody has a better suggestion....
It doesn't have to be aesthetically stunning as I can cover things up with plants, etc.
Excuse the mess, need to get a skip booked.
Ben
- Dig a hole in the middle of it, and put a flower bed in - this would catch a lot of the water I think, but not all of it.
- Dig a trench along the width of the garage, and create a soakaway. There is already an approx 1cm cut across the width - perhaps this is the drainage.
- Resurface the slab, creating a slope towards a single location (e.g. garden or soakaway) - this would need some co-ordination with replacing the garage doors, as raising the height of the surface would probably create a lip that would prevent the doors from opening. I have plans to replace them at some point, but hadn't been planning on doing it this soon.
- Rip the whole lot up and start again (not sure if the slab doubles as foundations for the walls at either side).
Ben
