I would like to install a woodburner stove in my lounge. There is a deep hearth there (6 feet of brick and concrete!) which extends 10 cm each side of the opening and 35 cm out.
I would like to add a thick limestone slab hearth on top and I have one that fits exactly and would look great.
The limestone slab would extend 400mm from the front of the opening. Building regs state it must be 500mm now.
Will the HETAS stove installer insist it needs to be larger? How strict are they on this type of thing? I know it is totally safe (and in fact the small stove I'm getting doesn't even require a constructional hearth as it has bottom heat shields).
I just dont want to install the hearth and then have to remove it all. Is that likely?
