Odd question, but is there a guide as to the strengths of different timbers? My new garage is having an inspection pit (with ventilation, gas sensor, tanked and with a sump etc before we get into a conversation about the pros and cons of inspection pits )
Typically, a pit would be covered with boards to prevent people falling in when it's not in use. More often than not though, the pit is in a location eg a single garage) where a car would not be able to get a wheel down the middle of the boards, and so the boards only really need to support the weight of a person.
My garage is going to be quite large, and it will be quite feasible to drive a car with the wheels of one side right down the middle of the boards covering the pit. Now, of course I don't want to end up parking a car in the pit, so what sort of thickness timbers should I be aiming for, and what type of wood? The pit is 3.5m long, so there will be few of them, and I don't want them to be so heavy they can't easily be moved, nor do I want them to be so many that it takes forever to move them.
The pit is 910mm wide, internally, with a 100mm recess around the top for the timbers to pick up on at each side - so the timbers will be 1.11m long. The recess will be 150mm deep, so this is the maximum I can go to, but ideally I'd go thinner and fix a timber along the recess for the boards to sit on.
Any suggestions?
Any suggestions?
