I just wanted ot find out how the thermostat works, and also how thermo valves work?
If there is a thermostat in the hallway with a TRV valve, then the thermostat would trigger the boiler for heat if the temperature goes down. So how does the the trvs work on each room? for example, heat will be called if hallway temp goes down, so how does the thermo valves in each room work ? what do they do ?
