How thick for a door jamb?
5 Jan 2016
Lancashire
I'm making an internal door lining and I'm wondering how thick to make the jamb on the hinge side. I can get 21mm (after planing) boards very easily, but this looks kinda puny, especially after rebating for hinges. Next size up is 33mm which is rather too thick and will reduce the available width of the aperture (I'm trying to keep it as wide as possible but am limited by the length of the lintel).
No one seems to stock 27mm round here which looks ideal. :rolleyes:
That said, I have seen off-the-shelf door linings that are as thin as 19mm! :eek: Am I being too conservative?
your hinges will use no7 x1 1/4" screws so 32mm
you may get away with 27mm and 1" screws ??
With the architrave mouldings on the outside of the door jamb, you wouldn't really know what the depth of it was. In theory, if you could securely fit a piece of backing wood where the screws are going, then 21mm could be achieved.
I needed a few very wide linings, beyond what is readily available so ripped down 25mm mdf.
Seriously? :eek: No way my doors would hang off MDF. They'd rip the screws right outta there...
I think I'll do this -glue some strip wood behind the areas where the hinges will be.
as an aside
you only need the 33mm on the hinge side the lock side can be 18mm
indeed iff you get an 18mm frame then double up on the hinge side
although i think thats what you have just just suggested
is this in a studwall or brick wall ??
if its a stud then assuming its flat and level then fix the hinge side to the stud and go with 18mm and 35mm/1 1/2"screws
iff you get an 18mm frame then double up on the hinge side although i think thats what you have just just suggested
Yes more or less. It's a brick wall, but only single skin. There enough thickness of plasterboard for me to fit some stripwood behind the hinge area without even needing to gouge out the brick. Problem solved I think!
Your door would have to weigh a few hundred kilo to rip out the screws from mdf.?
Much stronger than same thickness of timber as it's far denser.
mdf is a great and a horrible material in equal amounts
its very heavy for its strength as its short random wood fibres compressed so about 5 times the volume to get a workable material
it de-laminates in the end grain or near the edge
screws that will normally move the wood fibers and go in between can delaminate and or cause bulges in the board
it is useless if it gets wet
then the good points
very easy to machine and cut without splintering as theres no grain
it gives you a fantastically smooth face for painting
iff you do a pilot in the face you will find it very difficult to lever any screw out because off the densety
Gerry, you're trying to get the maximum width possible, but you haven't mentioned the depth of your door stops you're going to use, as this is the normal place to try and increase the width.
But it's so fibrous? Then again I've been wrong before.
Believe it or not quite a few door casings installed in public buildings such as colleges, office blocks, etc use MDF casings carrying relatively heavy doors. The trick is to ensure that the MDF casing is properly fixed to the stud work (often using double rows of screws) and that good quality screws are used for the hinges and that they are driven into correctly sized pilot holes
Gerry, you're trying to get the maximum width possible, but you haven't mentioned the depth of your door stops you're going to use.
Oh I'll just buy some stripwood or something. Basically I have two doors available, one 700mm wide, the other 800mm wide. I'm trying to get the doorway as wide as 780mm so I can use the 800mm one (cut down).
