Hey everyone,
We are redoing our bathroom and want to put in a wall hung toilet. The bathroom is already relatively small and we want to make the frame and concealed cistern as thin as possible so the boxing in isn't too deep. It's against an external wall of the house so can be attached directly to the brickwork which should make it more stable than a stud wall. I have found a couple of slim concealed frame/cisterns which should hopefully mean we only need a boxing in of around 10cm including the tiles:
http://www.ergonomicdesigns.co.uk/1...html?utm_source=GoogleBase&utm_medium=organic
http://www.livinghouse.co.uk/acatalog/Super_Slim_In_Wall__Cistern_Kit_for_Bathrooms.html
We are most likely looking at one of the following toilets or a similar Duravit one, presumably all toilets have the soil pipe and water inlet in the same position so this toilet would work with these frames?
http://www.qssupplies.co.uk/bathroom-furniture-shower-taps/24485.htm
I wanted to see if anyone had any views of these slim frames and whether they would be sturdy enough (I assume the Geberit one will be as they're a good brand) and the flush volume/flow would be the same as a normal cistern or less? The intention would be to have this and tile in front of it with access to the cistern through the flush plate and also from a removable shelf above. I would be very grateful to hear peoples opinions on these and whether there are any particular positives/negatives or any good slim alternatives?
Thanks so much,
Dave
Thanks so much,
Dave
