Hello and thank you for looking at this post, its probably a repeat matter.
Part of my bathroom refit is the installation of a shower above the new bath. There are pipes there for the bath (which is going in the same place as the old bath, two taps).
The shower will be fitted to the wall above bath taps.
Can the existing bath hot and cold water supply pipes just be t-ed to link to both bath and shower and will this achieve equal flow rate if there happened to be both shower and bath taps on at the same time, ie no hot or cold surges to shower if bath taps then switched on.
Thank you for looking at this post.
This is a temporary bathroom for about a year until an extension is constructed and bathroom is fitted professionally.
