Hi there,
I have an outside light that lights via a PIR.
Due to it's location we don't get any of the light on the front door.
I thought about mounting another PIR light and feeding it from the existing lights supply. (see photo).
The existing light is mounted on the outside wall of a small toilet that has been decorated last year so I don't want to do any damage to the bathroom inside if I can help it.
I just wanted advice on how you would go about feeding another light? Would you run a cable from the existing light up under the eaves and down to the desired location (I was thinking of using 1.5mm armoured cable cleated to the wall)? Or is this a no-no?
Or would I put a waterproof junction box at the position of the existing light to take the existing supply into and then tee off and re-site the existing light and a new light?
Any ideas / advice?
Any ideas / advice?
