Hi all
My dishwasher (indesit DIFP36) is not filling with enough water which is causing a number of issues: you can clearly listen the re circulation pump pulling air then water (then air then water...) wish cause all sorts of issues (one of which is not washing properly and not rinsing properly).
I've tried opening the machine's door while it's washing and manually throwing in about 1L of water and when it resumes it starts working properly so I'm quite sure the issue is not filling with enough water.
After much Googling I found some posts that suggest how to adjust the pressure switch but the one on my machine seems to be different.
I have one of these: "Indesit Group Pressure Switch 85/65 DEA602" (such as the one shown here http://www.buyspares.co.uk/pressure-switch-8565-dea602/product.pl?pid=2276353)
Instead of just one screw as mentioned on many posts, this one has 2 screws. My question is really which screw adjusts the filling level.
I've looked inside the machine and I could not find any easier way to adjust this. There is an air tube that goes from the bottom of the machine (ie the recipient just under the metal grid inside the machine) directly to this switch and that's it.
I've blown into the switch and you hear the clicking sound when pressure increases so it should be ok.
Can someone please point me to where I can find information about adjusting the pressure switch or, otherwise, if there is any simpler way to make the machine load more water?
Pedro
Pedro
