i have noticed many articles on various forums over the years discussing the extremely annoying occurance of crinkling when bending copper pipe with a pipe bender.
i have a really cheep 15 + 22mm pipe bender that would sometimes make perfect bends and at other times would make crinkled ones. i tried a steel shim on top of the aluminium former to advance the bend fulcrum with mixed results.
Eventually i found what appears to be the answer and that is keeping a constant pressure whiles bending: relax the force on the arms for a second [ie stop and start] whilest bending and you'll end up with crinkles in the copper.
However when you need to stop the bend to check the angle KEEP THE BENDER ARMS UNDER PRESSURE without further actuating the bend [It can help to rest one of the bender arms on the bench/floor to free a hand to do the measuring]. If you need to take the bend further increase the pressure again.
It takes a while to get your head around but eventually you'll get the knack of it and you'll throw even, smooth bends everytime
cheers, waltwales
cheers, waltwales
