Last year the pipework leading down to our outside tap split in the heavy frost . . . this despite me turning off the water from inside the house and leaving the tap open during the winter.
I assume there was still some water remaining in the pipework. I would like to avoid the same happening again. Should I :
1. Turn the water off to the property
2. Turn on and drain the bathroom taps (the outside tap is fed from the bath)
3. Turn on and drain the outside tap.
4. Turn off the bathroom taps
5. Turn the water back on to the property.
6. Leave the outside tap open over winter.
Is this correct and will I have more chance of draining the pipework of water?
Thanks.
Thanks.
