Hello. What I am asking may seem to be about something that is obvious, but I need to be absolutely sure about it. Our fridge and freezer need replacing, and the space for them (under the kitchen worktop) is limited. When a fridge or freezer is viewed on a dealer's website, usually, its dimensions are stated (H X D X W). It's easy to see what maximum height or width is needed, but, because of a concern about buying appliances that are too big to fit, I am not 100% sure of what the official depth of an appliance includes. I shall explain.
At the back of our freezer, there is a grid of fine pipes (a cooling system, no doubt), which stand off from the actual case of the freezer. Then hooked onto this grid are two "buffers", which prevent the grid from being damaged by impact with the wall behind the freezer.
What I need to be sure of, before ordering new appliances, is whether the grid and/or the "buffers" are included in the depth in the dimensions stated on the website, or whether it refers to the depth of the case only.
It seems reasonable to assume that only the casing is measured, and that the grid and the buffers are not included. However, I need to be sure. I should not like to order goods of the wrong size!
Also, some fridge doors bulge (are more curved) than others. Is the depth of a fridge measured from the straight line behind the door, or must it include the bulge of the door?
Can anyone with knowledge of the white goods trade say, with certainty, what is included in dimensions stated on websites? My grateful thanks, if you can.
A.W.
A.W.
