How to best mortice out a door jamb / frame ... ?
9 May 2014
Dorset
Hey ... just bought a really great bit of kit to help me fit loads of locks - basically a jig that clamps to the door and allows you to use a power drill to rout out a perfectly centred mortice which will accept the lock and face plate.
However ... the jig is too narrow to enable one to then fit it to a door jamb or door frame. I have looked high and low on the internet to see how joiners normally go about the routing on a door frame, and just can't find ANYTHING! Is this some sort of dark secret art? Or is it just a case of drilling out with a wide flat bit, and then chiselling out everything else by hand?
Any tips/ideas/secrets would be very gratefully received ...
wouldve thought within the kit you would have the jig to enable the cutouts on the frames/linings?
look on ebay for lock jigs etc.
or if you can do it ,make up a couple of home made jigs.
you say you can use an ordinary drill, instead of a router?
have you got a link?
you normally use the keep as a guide to chisel out the shape a job not really suited to a jig ??
This link for John D:
http://www.ironmongerydirect.co.uk/...e_locks_and_latches/55011/dbb_morticer/247397
It does work very well ... but as I say, it can only cope with doors up to 55mm thick.
gregers - I think you're right, I'll have to make my own jig up and use a router rather than the DBB morticer. Just find the whole chisel & mallet thing very time consuming, and love the cleanliness of something routed!
Just use a drill to make mortice and clean up with a chisel, matter of minutes.
Thumb plane helps sink any plates.
Thanks - I'll look at a thumb plane, hadn't heard of that before.
Well - now done three with just drill & chisel - actually, you're right, doesn't take too long, and is quite flexible in a way.
