how to bleed firebird oil burner
11 Dec 2009
Armagh
Hi
Need to know which nut to open to bleed this firebird oil burner (photo attached).
Ran out of oil, now burner kicks in for 5 mins, then gets in too hot and cuts out with steam coming out of over flow valve, only kick in when cools down and after i have pressed the thermomstat reset button.
It wouldn't run at all if your oil needed bleeding. I suggest you check your system pressure and remedy it, sounds like the pressure is too low.
