I am sure it has been asked before and I have looked at a lot of posts before but this is a specific query.
I have just insulated my loft and put boards down and now I have some lighting cables coming through and over the insulation over short runs (all the main electrical runs are in open air running between the roof joists). Therefore the only cable under the insulation are the links between individual down lights, which I have placed within metal insulation guards).
I read on the forum that a 1.5mm Twin earth cable is rated for 3600w. I have also read elsewhere that 60% of the capacity of the cable can be lost if covered within insulation. On that basis the 1.5mm cable used should be good for 1440w?
The maximum power running through a single cable within covered insulation will be 114w as I am using LED 9w Aurora down lights. By my calculations I should therefore be well within the tolerance of the cable that I have used.
Can anyone tell me if I am approaching this calculation in the correct way? Or if my calculations are wrong?
I intend on also asking my electrician who I will have around to rewire my consumer unit in 4 weeks time, however I want to check I am safe in the mean time.
Thx,
Jon
Thx,
Jon
