If the filter is the paper cartridge type, it's hiding inside a black plastic canister with 4 allen head bolts on it bolted to the top right of the engine. Undo the bolts and lift the top off, swap the filter and rubbers and put back together. There will also be a hand priming pump which is like a black rubber lemon (??!). pump it til it goes hard, then job done.
