Just moved into an old house, and trying to replace a double light switch to a double dimmer light switch.
The current switch operates the wall lights in the through lounge, so we have one room with 3 wall lights and the other room with the same, no ceiling lights.
The wiring is as follows; two red wires and one black wire, there is also a red crossover wire linking both L2s together.
L2 = black wire, L2 = red wire and L1 has a a red wire which crossover to the other L1.
We thought maybe a dimmer switch was not possible, so purchased a replacement double switch. However, when we rewired this exactly the same, nothing worked at all.
Thanks.
Thanks.
