- Joined
- 24 Nov 2004
- Messages
- 431
- Reaction score
- 5
- Country
We are trying to eliminate some problems with a pair of large and rather ancient dynamos (10kW ish size).
the dynamos are compound-wound:
- series field coil in the power take-off circuit
- shunt coil controlled via rheostat to trim the line Volts.
the behaviour of these ostensibly identical dynamos under load differs (one appears to be behaving under-compound and the other over-compound).
We would like to eliminate the series windings from our investigations. It is practically very difficult to dismantle the dynamos in order to conduct physical examinations of the windings.
of course the series windings are necessarily very low in DC resistance, so comparing the 2 with a Fluke meter doesn't yield much intelligence. (both present about 0.02 ohms)
clearly neither of the windings are open circuit (each dynamo can do hard work on its own). but there may be one or more shorted turns (?) which could feasibly affect the "gain" of the series field arrangement.
are there any "wizard wheezes" to check the physical/electrical characteristics of the windings without dismantling the dynamo?
