How to check for leaks?
11 Dec 2010
London
Hi all hope you had a good Christmas? My combi saunier duval sd30e is loosing pressure and the DHW doesn't work most of the time, until I fill the boiler up with the filler loop.
After searching around I believe there must be a leak somewhere? It can't be upstairs as I would see the leak from gnd floor. Is there a solution that can be run through the CH to stop the leak? I have carpet in 1 room and large floor tiles in the other room and it's not going to be to take this up. Please help thank you.
How much pressure are you loosing over what time.
What pressure are you topping up to.
What pressure is the system reaching when hot.
Have you checked that the pressure relief valve isn't discharging. :?:
Andy.
The only way to check for leaks on visible pipe work is to let the heating go cold, otherwise any small leaks would not be visible as the water would evaporate and you would not notice it.
Hi all hope you had a good Christmas. Is there a solution that can be run through the CH to stop the leak? I have carpet in 1 room and large floor tiles in the other room and it's not going to be to take this up. Please help thank you.
Yes there is - and you can get it in a pressurised container like an aerosol - Inject into a rad that you have drained some water out of :idea:
I think Nigel F means Fernox Leak Sealer.
thanks for your replies guys
upon looking at the boiler again i have a weeping leak underneath there is a bit of corrosion around a brass pressure gauge connection, im hoping this would be the cause of the pressure drop however would this be enough to drop the pressure from 2 and a bit bar to just under 1 bar in a few hours while the CH and random DHW is used?
im having to top up the filler loop every few hours now
Hi, I have same problem, had it for years. Just put a tube of Fernox F4 into rad, says it doesaup to 10 rads. I have 13, some are doubles. Repressurised boiler. Checked PRV.Still leaking. Wonder if another tube of F4 is called for. I,d have thought over 5 days, even a weak solution would have sealed a small leak.? Hope not Butting in on OP.Joint problem shared.I know how he feels. It,s driving me barmy.1 £ 15.95 @ homebase. £20+ elsewhere. 290ml condensed with rad injecter for mastic gun. Liquid bottle £12, Presume the 2 will mix?
right sorted out the weeping leak from the boiler, i thought that issue was fixed, still losing pressure i put it to 2 bar and after an hour or so using CH drops to just under 1 bar. so i still must have a leak somewhere.
will i need bleed the rads at all?
how does the leak solution work sounds like i need to drain the boiler?
also just a thougt i have been filling quite a bit of extra water into the system, not sure how accurate the pressure gauge is will it do any damage to the boiler/CH?
seen this
Fernox F4 Express Central Heating Leak Sealer 265ml
think ill get some tomorrow
Andy.
Hi Andy yes the overflow has some water coming out so it looks like no leak on the rads...
