How to cleaning sockets and switches?
19 Jul 2004
I've been doing some decorating and managed to get filler and emulsion paint on the sockets and light switches. Whats the best way to get them off. A mate suggested dabbing a cloth with spirit and wiping/scrubbing. Is that safe, is there a better way?
Just done the same thing. I used a sponge type sanding block gently, and then some white spirit.
If you are worried, turn off the electrics as I once got a belt when I was overenthusiastic with the spirit.
Turn the electric off.
You can use a chiesel to srap the big lumps, then use one of those washing up spronge & scrourer things, easy.
Gently scrape the filer off then use a kitchen sponge scouring pad(the type with a course backing)used just damp.
If it is a few little spots i just use a new stanley knife blade. They come off quite easily once they have gone hard and this method does not damage if done gently. How much is on them? If they are covered with the stuff and they are basic white ones maybe it is worth replacing them as part of the make over of the room.
Martin
emulsion paint will soften with methylated sprit. To prevent it running off and evaporating, mix it with washing-up liquid.
Abrasives will mark the finish of the accessories.
if you are competent to remove switches and sockets and re-fit them correctly, you can put them through the dishwasher or give them a hot hand wash and scrub (it really does work)
John, are you mad?
Switches and sockets in the dishwasher? Hope you save some room for the consumer unit! :lol:
only the cover.
On the switches and sockets I have dismantled all the metal parts are brass (sometimes nickel plated) except for a stainless-steel spring for the switch click detent, and they are quite happy to be washed.
I am aware some some cheaper brands use galvanised steel for some parts.
only the cover.
At one place I worked at we used to repair PCB's for TV sets. When we got one in that was covered in carp we used a sink full of hotwater and plenty of detergent and a paintbrush to remove the gunk. Then 1/2 an hour under a heat lamp to dry it out. Came up like new.
Reminds me of the switches, with a big "X" scratched on them, where the decoraters trimmed the wallpaper, with a knife.
:roll: FGS :roll:
Next time, take them off the wall before you start painting!
Some people......
Isn't it fun having to pry off a painted in switch and patch up the plaster after?
Loosen or remove the screws, then tap the fitting a few times, breaks the seal cleanly.
Alternatively, a sharp blade at an angle to cut the seal.
I've had to replace loads of brass switches over the years where the X has gone through the laquer on the switch and the brass has tarnished as a result. :evil: :evil:
For small amounts of mess (splatters) I find repeated scraping with a finger nail works a treat - its softer than the plastic so you can give it some welly. If you've been really messy you'll have to resort to the methods above (not sure about the dishwasher though!)
