How to clip down very very small dia cable from magnetic sensor ?
4 Jan 2017
The sensor is basically the same as a magnetic contact switch on security systems, ie doors and windows.
A fixed magnet then a magnetic reed switch on the moving door. This switch has a flying lead buit into it. See SENSOR
But the cable is very very small in diameter approx 2mm , and I have to clip it to a wooden gate. The smallest nailed clip is 3mm dia (bell wire). So the cable sildes about in it. I have used it with a bit of packing in it, but it does not look good.
Any suggestions.
Staples.
I have a pack of stainless steel and with a bit of messing about you can nail one into wood without destroying it.
Wow, both sensor and cable look delicate. Would it be possible to chase out the wood to bury the sensor (countersink it) then chase a tiny channel with a Stanley knife to plop the cable into. You could tack the cable (and whatever cabling it’s extended with) into the channel with spots of epoxy and then fill it with silicone sealer maybe, so it’s removable if needs be. I’d feel the urge to give the sensor housing to make it less prone to a bashing personally.
would you not have the magnet on the gate and the sensor affixed to the gate stop as thats the only point it will be near enough to pick up the magnet ??
if you attach wires to a gate they may fail or get caught up and pulled off
