Hi
Can anyone please advise a foolproof way of making a once only watertight fitting connecting a 15mm brass compression fitting on to a plastic threaded connection on the waterfill on a toilet. The water is mains supply. Because of the lack of space around the toilet I can only make this connection once with no tightening the joint afterwards as I have to then work backwards to refit the toilet from this connection. Would you use PTFE or a sealant in the joint?
