click in that thumb image and you will see bigger image
BTW, I am using NYM cable , 3 wires ( brown, blue and Yellow/green)
I connect blue to N, brown to L
and I don't know where to connect Yellow/green, it goes nowhere
this way nothing works =/
so what is wrong?
could someone how to connect ? where every wire must connect ?
thanks
Yellow/green is the earth wire and must not be used for anything else!BTW, I am using NYM cable , 3 wires ( brown, blue and Yellow/green)
You need a three core heat resistant cable (or 3 core plus earth).
Brown to L, Blue to N at both ends (as your red lines)
Third colour to NO at Salus and 1 at boiler
Remove link between L and 1 at the boiler
Insert a link between L and COM at the Salus.
If your cable has an earth wire, connect it to the earth terminal of the boiler and make the other end safe in a terminal block.
