Hello
I've just been doing some investigating of my existing wiring as I want to spur some power into a lean-to (which is the subject of a separate topic titled "Electrics To Lean-To 'Outhouse'".
Turns out the existing wiring it is non-compliant! I have a ring-main (on a 32A MCB) that feeds sockets in the kitchen, (as well as an electric oven (the hob is gas)) and also a double socket in a separate 'utility' room. All good so far.
There is a spur from this double socket, to another double socket (in which the washing machine and dryer are plugged into). Again, all good.
However I have noticed that they have taken another spur off this double socket to power the gas boiler (which is located in an external cupboard that is situated under the stairs to the maisonette above).
So this is a unfused spur of a spur. Bad! I was hoping the spur to the boiler had come directly off the ring main, as my plan was to replace this with a FCU so I can spur to the boiler and then onto my new lean-to outhouse.
How do I remedy the current wiring? I assume I have to in order to get the new electrics in (and to) the lean-to certified. Ideally I'd like to fit an FCU between the first unfused spur (the double sockets) and the boiler. That would be ring -> unfused spur -> fcu -> spur [boiler] -> future spurs. Is that allowed as the first spur in the chain is not fused?
Fitting an FCU before the first spur (so that all the spurs in the chain are fused) isn't practical without channelling out a new back box into the wall (as I am guessing a 2G double socket FCU doesn't exist).
Any help much appreciated.
Thank you.
Thank you.
