A general question this ... just wondering how does one best make nice clean cut outs in wood? eg. if I want to make a 100mm x 50mm aperture in a piece of 25mm mdf, at the moment I drill out the four corners and then use a jigsaw which invariably ends up looking a bit shabby. Not only do the lines of the cut out never look particularly straight, but the cut edge is never vertical either. I know my jigsaw is pretty second rate anyway, but I get the impression that most jigsaw work is hard to get looking really good.
What is the pro way? Using a router? In which case, what kind of bit do you use, and is there any tool out there that would quickly make a frame to guide the router around the necessary dimensions?
Thanks!
Thanks!
