Hi
I have to make a couple of cuts in a 22mm pipe run but access is very tight. I have two 22mm pipes next to each other and the top is up against the floor above.
I have tried with a junior hacksaw but I can only get so far into the pipe before I start to foul the pipe adjacent and the floor above. I can move the pipe enough to get a few mm above and around it but not enough for a pipe slice to rotate.
Any tips? Does this kind of tool deal with this
http://www.screwfix.com/prods/45590...Tools/Pipe-Cutters/Ratchet-Tube-Cutter-6-23mm
