I want to cut a rectangular hole in a glass door at home to install a doggy-door. I was wondering if there is any safe/reliable way that I can do this. I have a drill-bit for glass so the bolts won't be a problem. It's just the main hole I'm not too sure about.
I've used a glass-scourer before, but I don't know how well it can be applied to only cutting a section of a piece of glass and not the whole thing...
At the moment I'm thinking of scouring out the rectangle and the diagonals, then drill holes in the corners and the centre, then tap out the glass...the only problem is that I can see the entire thing shattering to pieces...
Any suggestions will be very much appreciated.
