I am doing a bit of DIY arial maintenance.
I am splitting the cable outside to then run into the lounge and bedroom. I have all the relevent connector boxes, cable etc etc but I have a question.
How do you cut the cable to then fix the Connectors to it and do I use satellite connectors or normal coaxial connectors?
Also, can I use satellite cable or do I use normal coaxial to run into a normal TV and then a Freeview HDD DVD Recorder? - I think the main difference being the signal strenght down the cable??
Thanks peeps
d
Thanks peeps
d
