I am a woodworking neophyte. I have 10x10cm blocks that I'm using as props under the feet of my bed so my Roomba can get under there (without the blocks it's about 2mm too low!)
The bed has L-shaped feet and they slide around on the blocks. All I want to do is cut an L shaped channel in the blocks that the feet fit into so they won't slide off.
What's the best/easiest way to cut this L shaped channel into the wood? It doesn't have to be particularly perfect, just good enough for the feet to sit in there and not slide out.
In case it matters, I believe the wood is Oak.
Thanks for reading!
Thanks for reading!
