I am in the process of removing a sink (see pics below).
I am going to temporarily cut the hot and cold pipe, and cap them, and then later raise the floorboards and cap them off properly.
How should I go about dealing with the waste pipe? It is in a first floor bedroom and, for now, I had just planned to cut it, close to the interior wall, and then deal with the remaining pipework later.
Outside it runs down to a open pipe, shared with a drainpipe, which then runs to the ground and then the main drain a couple of meters away.
I just want the pipe cut so that I can get the sink out of the way.
The waste pipe is metal, not sure what type.
If I cut it, what should I use, and do I need to cap it off, or sever the external pipe to prevent any return of gas? (not sure if that is a problem as the pipework is open where the external pipe meets the drainpipe)
Any thoughts would be much appreciated.
