I am helping my fiend with his plumbing and we need to join a sink waste into the soil stack outisde which is cast iron for the first 8 feet or so. We thought it a good idea to change the bottom bit to PVC so that it is all PVC but it is so tight to the wall, and you can see the top of the clay pipe above ground which is nearly a third buried in the wall (see picture) God know why they installed it like this.
At first we were going to change the bottom section to PVC but because it is so close we then thought to use one of those chain cutters about 10inches up and use PVC from there but it does not look like there is enough room to do that even.
I have fitted a boss connector, to cast before and I know it was not that easy, it took a few broken drills and nearly burnt out my hole cutter, and we would prefer changing the cast if possible.
So what should we do? Would cutting it with a grinder be successful do you think, I would be worried on the cast moving and biting the grinder blade?
Hope picture is big enough, not sure how people get theirs to be zoomible on here.
Any advice or help appreciated.
