I need to replace the window seal on the interior side of a glass door. The old seals were cut at right angles in the corners which didn't look very nice so I was thinking of cutting the new seals at 45 degree angles to make a neater join. But I then found this YouTube video (
) which shows, rather than making a cut all the way through at 45 degrees, it takes a V piece out (without going all the way through) and this seems even neater. I don't have the special tool they have on the video but I could do this manually as I only have a couple of windows to do.
Thoughts on the best way to cut window seal/gaskets on the inner corners?
