I've a rainwater down pipe that is fixed at the gutter and attaches to a pipe that goes into the ground.
I need to dismantle it to remove a blockage near the ground.
I've removed several brackets and loosened the joints but still can't get enough movement to separate the pipes.
Do I need to use a long ladder and remove all the brackets / loosen the gutter fixings or is there a cunning trick I'm missing?
Thanks for your help.
