We have two of those designer type coiled spring radiators and I need to remove one of them because the fixings for it have become loose.
I am an electrician by trade and have never done much work on central heating systems before so bare with me if this is a stupid question.
The radiator is downstairs but is fed from upstairs via two surface mounted pipes running down the wall to the bottom of the radiator. If I were to shut off the combi in the loft, making sure the water feed is turned off, and open the drain next to the last radiator the system should start to drain down as I opened the bleed screws (starting upstairs) on the radiators.
My questions is how do I actually drain the water from the spring radiator, as with it being fed from above presumably means the water will only drain from the upstairs radiators and none of the downstairs ones?
Does the water need to be 'pushed out' some way?
Any pointers most welcome,
Sean
Sean
