How to extend the width of a Kitchen worktop not on the wall
18 Jul 2005
Lancashire
I am installing a new kitchen into the house that Jack built. The walls are not straight but bowed so I end up with a gap in the middle of the worktop against the wall.
I have thought of a few things that have worked in the past but they don't seem to be appropriate for this job
Digging the wall out at one end to reduce the gap is not an option as the units would be flush with the worktop, also the units are already in place and the joint angle would be wrong then.
Reducing the units width to allow an overhang on the worktop is not an option as the stove would be proud of the units.
any positive comments would be gratefully recieved
i think that not only do you dig out the wall but you need to remove the offending units and cut them back a bit?hopefully there should be somewhere of about 50-60 mm behind them,think its going to be a pain in the ar5e but at least this will give you a decent finish,can see any other way personally.
Change your worktop for a double post form one which will be 650mm wide, you then have enough to cut off the back
Jason
alternatively are upstands available that you could gain an inch or two by pulling top forward a little.
Jason
Yep , I'll second this post.
Get a wider top and scribe/dig out wall to suit.
Cheap option is to baton rear wall and add new plasterboard to bring rear forward to required depth.
If the wall is bowed in the middle and you have a gap, you will need to cut the units at both ends of the wall so that when you cut the worktop to fit, the front will be the same all along.
Its not really a case of getting a wider worktop, this just defeats the object (although it would work but at more cost)
Cutting the back of base units in kitchen fitting is done pretty much on every kitchen as walls are never usually straight, take that into account when planning your unit layout.
Andy
