I have a recently installed vaillant ecotec 937 and I would like to know how to increase the internal central heating pressure - it's all working fine, but I will need to take a couple of radiators off shortly to do some decorating and am concerned that refilling them after I put them back will lower the central heating pressure below 1.0 bar. It's currently hovering between 0.9 and 1.0 bar as measured by the indicator on the front of the boiler. There is a braided loop-type thing underneath; am I correct in assuming that this is the filling loop and I can simply open up the (currentl closed) tap at one end of it until the pressure has increased to something higher (e.g. 1.5 bar) then close it again, or is there more to it than that? I took a look in the instruction but there wasn't anything obvious in there, so any help/advice very welcome...
thanks
Ben
thanks
Ben
