View media item 72544
Hi all,
Hope someone can advise on how to finish hipped roof ridge slates!
At the end of each row of slates I need to cut triangular pieces to finish against the hip rafter. Trouble is there is no batten left to nail these pieces to!
On two previous faces of the roof (there are 8 faces) I drilled through the slates and pegged the triangular bits on with slate nails. However, it was a sod of a job and I don’t fancy doing the other 6 faces the same way…
The temptation to use adhesive is raising its head but I expect this would be frowned upon…
The ridges will be finished with lead. Overlaps slates by about 150mm.
Anybody done such a job before?
Hi all,
