my roof is 8.5mts long... 6.5 mts is a lean too but the other end approx 2mts there is a parrapit wall which i need to have a ridge tile for,, can any one tell me what this ridge tile is called,,, or any other sugestion ,,, my roof is 15 degree if it helps ?
thanks woody that what im after ,,, also as im using redland regents which have a deep profile is it a case of sealing with sand and cement or is there a better way?
You would normally cut some plain tiles down and put these in the troughs of the regents. These are called dentil tiles and allow you to use less mortar.
