If there's no tension adjustment, then put the belt on the smaller/smallest pulley first and the bigger/biggest pulley last.
If you can adjust the tension, then slacken it off first, then fit the belt, then adjust so that you find the midpoint between the belt going "twang" like a bow string and being so loose that it smacks other components as it goes round.
Condenser drier with a big pulley which make/model have you been fitting belts to softus. Sorry fr not a simple job and usually a reason why belt snaps.Check if drum is rotating freely Check the jockey wheels are turning freely these are the wheels the drum sits on and turns the drum rotates.
