How to fit kichen plinth so as to be removable?
7 Feb 2006
I will have an integrated dishwasher in the middle of a run of units. I want the plinth to be removable for obvious reasons. How do you suggest I secure it?
:idea: Choose one ;)
Magnetic Catch
Panco Catch
Plinth Connector
Available from here
If your units have standard plastic adjustable feet such as these:
then they will come with plinth clips (two pwr base unit). So long as your plinth is clipped to legs on the units either side of the washer and entire section can be unclipped and removed for access in one go. I feel that this looks neater than having a plinth run made up from several different pieces
Scrit
I have the plastic ajustable feet like scrit's pictures but how do you actually pull the plinth off? Is it a case of putting something behind at one end and levering it off? I am concerned about damaging my nice new plinths! ;)
Thanks for the tips Big-all.
I will check, maybe I'll be lucky and my kitchen fitters have made that semi circle...but I doubt it! :rolleyes:
