How to fix down a toilet but cant drill due to waterproof membrane
7 Jan 2012
Wiltshire
Let me start by saying that I have already read the other threads on this subject... my situation is slightly different because I can't just drill into the floor, much as I'd like to. And yeah maybe with a bit of forethought this situation may have been avoided but it is what it is now....
We had to have builders in to completely renovate the basement because the waterproof tanking appeared to have failed (or was badly fitted by the previous owners more likely). New tanking membrane, (wet) underfloor heating and porcelain tiles fitted and the builders have departed leaving me with the "easy" bits to finish. Which was when I realized that re-fitting the toilet was going to be a problem.
Can't drill holes to fix it down without penetrating the waterproofing. Wall hung toilet won't work either, for various reasons.
Quite a bit of discussion on here about simply using sealant but also at least one comment that suggests it'd "walk" over time and someone else suggesting that if you did too good a job at fixing it down then replacing the pan in the future could be difficult.
I had one alternative idea but I'm not sure how practical it is....
The tiles are 8mm in depth. It "may" be possible to very carefully drill down just 8mm and chemically bond a short bolt into the tile thereby allowing the standard toilet brackets could be used. This could be enough to prevent the lateral movement whilst sealant around the edge (and possibly more sealant underneath) would further lock the toilet into place. The bolts wouldn't be expected to prevent any concerted effort to pull the pan off the ground.
Or is that never going to work?
Is sealant my only realistic option?
Thanks in advance
Steve
But don't go made with it!
Just a bead so that it can be cut with a multi tool.
Thanks both. Being able to remove felt as important as getting it fixed because with the way my luck runs I'll undoubtedly needed to remove it at some point!
Glue a couple of lengths of timber to the floor and the screw through pan fixing holes into timber... Timber size obviously depends on pan footprint.
Having said that, I'd be using CT1.
I have plenty of pans stuck down with just silicone... This needs renewing every few years anyway as it gets grimy!
Could use timber glued down IF the fixing holes in the pan are horizontal.
Similar - use an anchoring resin (not 2 pack epoxy) to fix the pan side fixing to the floor, then use silicone to augment. Drill some shallow holes in the tile to provide extra grip.
