I want to build a hand rail up a set of steps by using 150 x 50 planks of wood mounted edgeways on against a brick wall.
What I am looking for is some means of fixing a bracket to the wall and then no more than 50mm away from the wall fixing the plank of wood by it's narrow edge. I was envisaging some sort of bracket wider than the wood with 2 bolts to fix to the wall then 50mm away from the horizontal plate a vertical plate to fix to the wood.
Anyone know where I can find such a bracket or is there a better way of doing it.
