We had our CH pipes relocated underfloor a while ago and the plumber cut an existing floorboard to get access. It squeaks whenever someone walks over it but I didn't pick this up at the time.
As the floorboard was cut to the side of the supporting joist it cantilevers off the adjacent joist and adding a few screws won't fix this unless they are put in diagonally (which I don't think will hold). My idea was to find a thin sheet of metal, punch a few holes in this and then screw in over both sides of the cut. I don't want to pull the floorboard up as it runs under a door threshold.
Has anyone had a similar problem and what did you do about it?
Thanks in advance.
Thanks in advance.
