Hi
My Garage had a white PVC Panel as seen in the photos which has come loose on one side.I think it was stuck to two narrow metal sheets underneath the panel and the panel was held in place with Silicon.
How should I go about doing this?
My plan,remove it completely,clear the adhesive bits and silicon.Then use an adhesive(which one?) and stick it.Then put the border silicon back in place.
If you think, that is the way to go ahead ,I have some questions.
1.What Kind of adhesive? Just ask at B&Q or something in particular?
2.Secondly once I use the glue,how long will it take to hold together? It looks really hard to hold it in place for long.Any suggestions? Do I need to hold it in place overnight?
3. Any particular silicon and do I fix it straightaway or wait for the glue to have worked?
4.Any other suggestions/ideas
