How to fix toilet pan to floating floor
Or Gripfil pink grip
Pink grip solvent version is the better than the solvent free stuff
Solvent free comes in a plastic tube, solvent based is in a cardboard tube
Don't use Gripfill.
Use fat screws the right length and some CT1 adhesive just to give some extra grip, as chipboard isn't great, especially when it gets wet. CT1 under the bottom rim of the pan, and around it too if you use the white stuff.
http://www.ct1ltd.com/ct1.html
Or mastic !
The only sensible answer thats been posted.
Obviously a generic term was used the specific "Mastic" is pretty much a trade secret.
Anyone that thinks screwing into chipboard is going to give a high tensile strength joint, clearly doesnt understand the comparisons between the pull out force values between timber and chipboard.
Have any of you taken out the screws and been able to move a correctly "Mastic'd" wc pan ? no they dont budge, you have to break the seal before it can be moved.
Tighten the screws too hard and whats the result ? a cracked pan.
The screws just hold it till the "Mastic sets.
Silly ,very silly, not helpful.
I hope the OP isnt put of DIYnot by this CRUD
If you cant offer good advice go elsewhere
Take up t0ssing, shopping or ironing but just go....
You talkin to me ? You talkin to me ??
You could have a field day on screwflux Moderator 10 :LOL:
I would have thought the best plan would be a frame and wall hung pan. :rolleyes:
