Evening all,
I've dropped a bit of a bo**ock this afternoon when extending an old pipe that comes out of the ground to use as a hose pipe.
I have been completely unable to locate any service valves for it so used a freezing kit to plug it while I cut the broken old tap off it to fit a new gate valve, pipe and hose tap.
Freezing went fine, I cleaned up the end of the old pipe, fitted the new bits and nipped everything up and then started tidying up while I waited for the freezing kit to thaw.
Got a bit of a fright when the ice plug went because I hadn't checked that the tap was shut so it suddenly started spraying water everywhere, but I turned the tap off and found a tiny leak spraying from the bottom of the gate valve.
I tried to nip it up a little more in case I hadn't tightened it enough and it made no difference so I obviously need to redo it.
Only thing is, I can't see the freezing kits working again if the water is moving through the pipe at all.
Is that right? If so, what can I do about that? How do you work on a leaking joint with no form of isolation?
Cheers all!
Cheers all!
