How to get molded plastic shredder hopper back into shape
Min
27 Oct 2003
So I finally worked out how to get the hopper off the garden shredder. Now I need to get it back to original shape. Boiling water isn't doing it.
It's molded black plastic. Friends are saying use a hot air gun, but surely this'll risk heating the surface too much?
I want to know if I can heat it in the oven. Maybe put it in cold oven and turn heat to 120C. Then gradually increase heat till it's flexible.
Melt temp websites list various plastics, lowest melt temp being about 162C (325F). (I don't know which plastic it is, so have to play safe.)
Any suggestions?
Btw, when the hopper got bent out of shape it had been in the hot sun all day, then 'set' in the forced, wrong shape. That was on the hottest day last week. Not forecast to be that hot again :(
A hot air gun - with care - is the way to go, as using an oven will heat the complete moulding up and you'd be lucky to get it back. If you can screw it back in place to hold it and then have a go you could get lucky.
John :)
Brilliant litl, ofcourse!! Will try that before summoning the courage for the hot air gun.
Thanks litl and John. Will let you know what works.
Car wasn't hot enough, but careful play of hot air gun on lower setting did the trick. All assembled nicely.
Thanks for your help guys.
