I've got a MS Excel file with 30 tabs relating to a separate issue. I update each tab as necessary. The file is viewed each day by one other. Rather than having to check every tab is there a way I can set the file so that it highlights the tabs which I've updated.
I thought of turning on track changes but I'm not sure if that'll hightlight each tab or discard the tracked change after its been viewed.
How can I set the file so that my daily changes (i.e. changed tabs) are highlighted when the file is opened, but then the highlight is discarded after its been read?
