How to insulate from cold a wooden single glazed front door.
26 Sep 2012
London
Hi Everyone,
Can someone please give me some advice on how to insulate a wooden single glazed front door from cold draughts.
Cold does not seem to be coming from door frame but the glass itself. The 12 single panes are on the door and 2 large panes to the side.
The glass has a ripple effect so not sure if windows films can go over it ?
Any advice much apprecaited.
Many Thanks.
It is possible to buy secondary glazing. A large single sheet of glass in a frame that you then affix to the frame of the existing window/s. My parents had them when I was young / still have them on a number of large windows around the house.
DIY secondary glazing you mean?
You mentioned that..
Or that plastic you fit in winter
Yes it is a permanent fix secondary glazing. I assume that they had to measure their desired size and was supplied accordingly. We're talking 40 years odd ago but still going strong now. It was bought primarily due to road noise issues but obvs helps with heat loss as well.
do NOT do a search for" secondary double glazing" or use the word "glazing" to avoid overpaying
just look up acrylic sheet and acrylic sheet clips or edging and order with enough margin to get fixings in
it doesnt have to be airtight as its stationary air
I have just posted a very similar question. Acrylic sheet seems like a good solution to my problem. How would one fix it to wood. With a specialist glue?
